Picked up one of these today for cheap. Few issues: Should this be variable speed? The power is either all or nothing... Does this have a forward and reverse? This appears to only go forward... Just need to clear this up, before i approach the seller! Cheers.
Single-Speed Variable & Reverse via a sliding switch. http://sdsdrillexpert.co.uk/drills/bosch-gbh-24v
Right, am I missing something here... Just got a replacement, and it does the same thing - the power is all or nothing, surely this isn't right, it's supposed to be variable, yes?
you have bought it off e bay i assume ?? if the electronics have given up the ghost he may have bypassed them or indeed they may just have fused hows was it descibed ??
Yes eBay, described as fully working... This one will be being returned too, think I'll look elsewhere.
I've got a Bosch 36v li-on sds, with the interchangable chuck, superb piece of kit, I'd definitely recommend it to anyone.
I got a Bosch GBH4DFE, which also has the interchangable chuck system, & I find the trailing lead is a hinderance at times, so looking around for a 36v drill.
