BOSCH GST 135BCE JIGSAW
Discussion in 'Carpenters' Talk' started by peterob, Sep 16, 2007.
  1. peterob
    peterob New Member
    NOT LONG HAD ONE NICE BIT OF KIT ONLY PROBLEM IS WHEN CUTTING THICKER MATERIAL IM FINDING THE PRECISION CONTROL BUTTON VIBRATES OUT SO THE JAWS ARENT CLAMPING ANYONE ELSE EXPERIENCED THIS
  2. foxy
    foxy New Member
    Never had it with mine. Phone Bosch and explain the problem, their aftersales service is A1.
  3. ozbob
    ozbob New Member
    i personally wouldnt use the prec control on thick wood,no need,its for scribe work realy,which would be 4mm/6mm sheets or skirt etc etc
  4. diva
    diva New Member
    I've got this jigsaw. Try turning the variable speed down. This is the dial on the back numbered 1 to 6 each of these represent rpm 1000rpm to 6000rpm try using it at 3000rpm & see how you go. I agree this is an excellant tool.
    Diva DIY
  5. Mountain Man
    Mountain Man New Member
    Nice piece of kit, but I've got a courier picking mine up tomorrow under warranty because it won't cut against a guide edge. Either wanders off or binds. When cutting free-hand, have to guide at a skew to get a proper cut. As I said to the guy at Bosch, with 30 odd years experience, It's not my technique thats wrong!
    By the way - first chap I spoke to at Bosch was very pleasant and helpful until I lost my phone signal. Phoned back - different bloke - COR BLIMEY talk about someone who is *** off and in the wrong job! Suicidal if you ask me!
    [Edited by: admin5]
  6. Mountain Man
    By the by the way, before anyone says it's my blades - I ONLY use Bosch blades from SF.
  7. HudsonCarpentry
    HudsonCarpentry New Member
    Must be the way you clamp the guide then... A MM ;P
  8. Mountain Man
    Like, there's more than one way to clamp a straight-edge to a board with an F clamp at each end?
  9. big all
    big all Screwfix Select
    wrong!
    sounds like its crabbing
    the blade is not running parralel to the base plate
    this can be caused by the blade clamp out or loose allowing the blade to go off line
    or the base plate not parralel to the machine body
    big all
  10. bonnie the botch
    bonnie the botch New Member
    hi ive omly just bought on of these jiggy's and cant make my mind up about it. it seems to strugle with laminate down blades, the work rate comes right down compared with my old makite machine. but over all genrally a good bit of kit although does seem to run quite warm
