Hi All,
As the title suggests, I'm experiencing a leak between the locking nut and adjustable tube of my bathroom bottle trap.
I have a couple of traps, done my absolute best to ensure all nuts are tight, waste is tightly connected, but seemingly nothing is preventing the water coming through when the tap is running.
The space is exceptionally tight, so fitting it all has been particularly difficult and I'm unsure if it's something I've done wrong, or if the traps I have tried are faulty.
The inlet is 32mm (basin waste 32mm), outlet pipe is 40mm. I'm currently trying a Euroflo 32/40 universal bottle trap with adjustable height, though I may not need the adjustable version if that is the problem...
Photos attached for context.
Any advice on things to try/test would be most appreciated. One thing that crossed my mind was shortening the adjustable tube since it's fully housed in the trap, but unsure if it would make a difference.
