Bowed double glazing
Discussion in 'Other Trades Talk' started by Dabbler87, Nov 8, 2018.
  1. Dabbler87
    Dabbler87 New Member
    Hi everyone
    I have recently purchased a 1970's flat that is in a bit of a state. There was a historical problem with sagging in the concrete lintels above the windows. These have since been reinforced but a side effect is was that the upvc window frames have bowed into two of the rooms. It is a very small amount (not even 1mm) but enough so that the seal is not tight, causing a lot more noise to filter through.
    I am thinking of replacing the existing seals with larger ones to give a tighter hold where needed. Does anyone have experience with this sort of issue and are there any recommendations on brands etc?
    Thanks!
  2. kitfit1
    kitfit1 Well-Known Member
    Which seals are you actually talking about ? The glass seals or the opening window seals ?
  3. Dabbler87
    I’m talking about the foam weather seals for the opening windows
