DIY Bobster
New Member
I am currently doing a bathroom renovation and decided on fitting a Merlyn Level 25 stone resin shower tray. In the instructions, the first thing they get you to do is check that there isn't an excessive bow on all four sides. They do this by getting you to prop up the tray on four blocks of wood and then using 3mm shims in the corners, run a level across each side and see if there is a "rock" in the level. In other words, if the middle of the tray edge bows upwards by more than 3mm. So obviously there is a 3mm tolerance on these trays, so some bowing is expected.
Tray numbers 1 and 2 failed the rock test and were bowing upwards, but only marginally (approx 1-2mm). Merlyn, to be fair to them, were happy to send out replacements. Tray number 3 didn't fail the rock test, because the bow was in a downwards direction (away from the ceiling) and was significant (about 10mm). Now if I was following the instructions to the letter, this wouldn't fail the rock test, so if this was the first tray I had received I might not have questioned it. However, Merlyn said more than a 3mm bow in either direction means it needs replacing. Tray number 4 came and same problem as tray number 3, but only a 7mm downwards bow.
Interestingly, I had a chat with the courier who implied this was quite common (and apparently even more of a problem with Merlyn Truestone range). One of the things that the courier also said was that even though the trays are supposed to be stored flat, when they get packed into the van they are stored upright placing all of the weight onto one of the edges. In addition to this, they can sometimes be loaded this way the night before delivery, so can be upright for 12-24 hours on occasion.
So many questions regarding this:
Rant over, thanks for reading!
- Is this a problem with all stone resin trays, or just low profile ones
- Is this problem with all brands of stone resin tray, or specific to the Merlyn brand?
- Would storing the tray upright for 24 hours really be enough to create a bow on what I assume is a solid product?
- What experience (good or bad) have people had with other similar trays and manufacturers
