box difference ??
Discussion in 'Electricians' Talk' started by Coolgit, Feb 2, 2004.
  1. Coolgit
    Coolgit New Member
    What the difference between 2G 32MM PATTRESS SQUARE CORNER SOCKET BOX BS5733 (11805) and 2G 29MM MOULDED BOX (43690) apart from the price ??
    cheers
  2. ban-all-sheds
    ban-all-sheds New Member
    3mm.
    And probably some quality too, as the 2nd one is made by Crabtree, and the first one isn't.
    Why does it matter to you?
  3. handyman.
    handyman. New Member
    The thickness of the walls (of the box). The more expensive one will take much more abuse. Depends where your going to put the box. If its going to get hit by a hoover then get the good un!
    I had the cheap one crack when I over tightened the screws (by a ba hair)
  4. handyman.
    I would think it matters, BAS, because if your going to get 20 odd to do your house their would be ££ difference that could be spent in the pub ;)
  5. Coolgit
    Coolgit New Member
    just curious.
    I did buy some 13 amp DG switch socket from screwfix and when i put a plug in and out the socket broke to 5 pieces. Starting to think why it so cheap quality issue need to be discussed.
    cheers
  6. lastword
    lastword New Member
    Always use the same make 'white' pattress as the fitting. Otherwise you'll see there's more than one definition of 'white'.
    Another little detail that separates pro's from diy ;)
  7. Milton Bradley
    Milton Bradley New Member
    Buy CRABTREE fittings and boxes, they are built tough, and will save complaints later on...
  8. ban-all-sheds
    There you are then - you <u>do</u> know what the difference is between an unbranded box at 66p and one from a reputable manufacturer at £1.25...
  9. andyboy
    andyboy New Member
    i bought the select range DBL sockets and they cracked and the shutters on the sockets jammed all the time.
