Boxing in steel lintels with 12.5mm Gyproc FireLine
Discussion in 'Builders' Talk' started by pal123, Apr 25, 2020.
  1. pal123
    pal123 Member
    I have put wooden noggins in between the RSJ webs. I have attached, at 60cm (or less) spacing underneath the RSJ, two long pieces of timber on each side. This timber forms the bottom frame for the RSJ with 12.5mm single layer of gyproc fireline plasterboard.
    I have used galvanized banding (metal strip) to secure the timber to the noggins. The timber is only tied into the noggins.
    Here's a dropbox link:
    https://www.dropbox.com/s/qlg5g9inwdllom6/20200425_212621.jpg?dl=0
    Do I need to further tie in the long timber before plasterboarding around the RSJs?
    Thanks,
  2. Hfs
    Hfs Active Member
    WTF is that :D
    Jord86 and Abrickie like this.
  3. Abrickie
    Abrickie Screwfix Select
    Thank you, I didn’t want to be the one to say it first ;)
    Hfs likes this.
  4. pal123
    pal123 Member
    Well thanks for your valuable contribution (heavy dose of sarcasm injected)
  5. CGN
    CGN Screwfix Select
    'Crack on'.
  6. Abrickie
    The disinfectant will take care of that :)
