BPEX or PBEX JG Pipe
Discussion in 'Plumbers' Talk' started by How?, Jan 24, 2008.
  1. How?
    How? New Member
    What's the difference?
  2. Captain Leaky
    Captain Leaky New Member
  3. How?
    How? New Member
    Hey Cap'n,
    I found that before posting, but what is the differencee?
    Regards,
  4. HOTDOG ø
    HOTDOG ø Active Member
    None of any significance.
  5. How?
    How? New Member
    Apparently not.
  6. Captain Leaky
    It does not make any difference as far as I am aware.
  7. Princess Xena
    Princess Xena New Member
    Maybe an email to JG direct will shed some light on this?
    Gota be some diff, or why make both with diff names etc?
  8. paaulyb
    paaulyb New Member
    After some research, I think the answer is in the way the molecules are bonded together, and additives for protection against chlorine attack. The pipe materials themselves are of the same type and classification.
    www.flowguardgold.com/PresentationsAndPublications/notAllTheSame.pdf
    http://www.phcnews.com/march07/pex.php
  9. How?
    How? New Member
    Reply from JG arrived.
    Quote: Speedfit make two pipes for plumbing they are BPEX which is cross linked polyethylene with a barrier.
    The other is BPB which is polybutylene with a barrier. Both pipes are approved under British Standards and WRc to the same temps and pressures. The only difference between the two is that the BPB is more flexable
