Bpex or Pex pipe?
Discussion in 'Plumbers' Talk' started by john.kreelman, Apr 30, 2009.
  1. john.kreelman
    john.kreelman New Member
    Short and sweet for your experts. Cold water feed above ground in house and also for central heating use. Don't want to have to buy two different as the Cold water feed is such a small distance. Pex is alot cheaper, can I use for both instances or is it best to buy the dearer and just use that for both?
    Ta
  2. hobhead
    hobhead New Member
    pex whilst cheaper is more rigid, not as easy to work with. I'd go with polybutylene PB.
  3. Tony Soprano
    Tony Soprano New Member
    CU wherever possible!Unless it is absolute necessity to use plastic
  4. imran_
    imran_ New Member
    AFAIK all Speedfit has a barrier in it - i.e. BPEX. Polybut is a lot easier to work with, not quite the untamed python!
  5. Oh NO NOT AGAIN.
    Oh NO NOT AGAIN. New Member
    Copper mate. Only cowboys fits Speedfit. That is why I use Speedfit all the time.
    Loz.
  6. GKU
    GKU New Member
    <u>Both</u> are suitable for your job , one is more flexible than the other thats all
