Brick Paver Driveway
Discussion in 'Landscaping and Outdoors' started by Andrew Halden, Nov 19, 2022.
Tags:
  1. Andrew Halden
    Andrew Halden New Member
    Just had a driveway laid with brick pavers. Just noticed that part of it looks as if some bricks have been laid upside down.
    Question is do these bricks have a right side and a wrong side or doesn't it matter?
  2. candoabitofmoststuff
    The ones I have laid definitely have a right and wrong side...
    Post a picture so we can see.
    Cando
    Andrew Halden likes this.
  3. Andrew Halden
    Will do this morning
    Cheers
  4. ramseyman
    ramseyman Screwfix Select
    Generally the upper side has a very slight chamfer along each edge, the lower side is square.
  5. Andrew Halden
    Struggling to upload a photo due to size but basically I've got a batch of bricks that appear to have a rough face with the rest of the driveway having a smooth face. I was just a bit concerned that water will get into the rough patches, freeze and then start to peel away as time goes on
  6. Andrew Halden
    I've got a small chamfer on all of them but the majority of the drive bricks have quite a smooth face but I do have a patch bricks with a rough face. Concerned that water will sit in the rough bits freeze and lift the face of the brick away over time.
  7. Andrew Halden
  8. Andrew Halden
    Bottom bricks quite smooth in appearance. Top ones look a little rough.
    Was going to go back to contractor but don't want to be bambusaled. Or appear an idiot.
  9. Cris 11
    Cris 11 Active Member
    looks o.k to me.
  10. Andrew Halden
    Thanks. Must be just me
  11. ramseyman
    Looks fine to me
  12. Mr Rusty
    Mr Rusty Screwfix Select
    Y, just slight batch variation. It's fine.
