Brickbond Tiling around window in Bathroom
Discussion in 'Builders' Talk' started by Cadishead67, Sep 16, 2021.
  1. Cadishead67
    Cadishead67 New Member
    Hi,
    I want to do a brick bond of 40 cm x 25 cm tiles in Bathroom. Trouble is, if I set out on the window wall, around the window (tiles centered around window) I get a slither on the left hand side. If I set out in the centre of the window wall, I get reasonable cuts all over but obviously the tiles aren't centered around the window.
    What would people do in this situation?
    Cadishead
  2. nigel willson
    nigel willson Screwfix Select
    Basically you need to do what looks best , your house or customer? If the latter shouldn’t you already know this?
  3. Cadishead67
    My house. I have tiled a brick bond before with metro tiles but that was a bath splashback. This time I am tiling the full room so I want to make sure that I set out correctly. I am starting on the window wall and then will carry the pattern onto the other walls. The best situation currently is when I set out from the dead centre of the room. The wall edges are good but like I say, it's off set slightly round the window.
  4. stevie22
    stevie22 Screwfix Select
    What does SWMBO say? Give her the options and get on with it.
  5. FlyByNight
    FlyByNight Screwfix Select
