Broken trickle vent replacement
Discussion in 'Builders' Talk' started by Harinder Dhillon, Apr 25, 2019.
  1. Harinder Dhillon
    Harinder Dhillon New Member
    All, need some help
    I have a trickle vent in a upvc window that needs replacing
    Firstly how do I measure for a replacement , so I get one with the correct size. Im guessing its screw to screw, full length and depth?
    [​IMG]
    Also the 2nd picture shows the outside. Do i need to replace these aswell? They seem like 2 plug in vents to me
    [​IMG]
    If i do need to replace the external ones how do i get the following outside flap off to get to them. Its very sturdy.
    [​IMG]
    Thanks in advance!
  2. Jord86
    Jord86 Screwfix Select
    Slide a Stanley knife in and prise off the end caps on the inside of the house, should be able to get at the screws then.
  3. Harinder Dhillon
    Whats the measurements i need? Also amazon seems to come up as the first link to buy these
  4. Jord86
    :rolleyes: If you take it off, you can measure it and get a replacement from Screwfix.
  5. gas monkey
    gas monkey Well-Known Member
    Can get larger and cover over if size no longer available
  6. Harinder Dhillon
    With screw covers off its 400mm by 18mm depth by 18mm height.
