Brother DB2-B755-3 Sewing machine motor upgrade
Discussion in 'Project Photos' started by Jitender, Oct 6, 2019.
  1. Jitender
    Jitender Screwfix Select
    Ordered a new servo motor for my mums sewing machine.
    Original one was a clutch motor, I thought I would try out the new motor as they get good reviews on energy saving and noise reduction.
    Old clutch motoe removed. Very heavy!
    New motor now fitted. Very straight forward too fit. The belt is too big, so ordered a new reduced size belt at 39"
    Motor in place. Need to sort out the light cable.
    On/off switch.
    Longer foot link rods supplied in kit fitted. Cut off the non standard UK plug and fitted a 2 pin UK plug.
    There is a power supply socket to power the LED light. Does anyone know what plug is needed too fit?
    KIAB likes this.
  2. KIAB
    KIAB Super Member
    Just happen to have the parts diagram on pc,as there was one on Freegle, but it needed repairing.
    https://www.universalsewing.com/images2/parts_lists/all/ekga4eld.pdf
    https://www.universalsewing.com/images2/parts_lists/all/8gg344nb.pdf
    Drop AE sewing machines a email, they supply the Brother Industrial machines for the UK, & may be able to help with led light.
    Most likely that connector might be unique to Japan.
    https://www.ae-sewingmachines.co.uk/sewing-room/industrial-sewing/single-needle-lockstitch/brother
    Jitender likes this.
  3. KIAB
    KIAB Super Member
  4. Jitender
    Did find this on ebay, its costs £6.19 including delivery.
    [​IMG]
    At present both the wires have a spade/fork connecter crimped on the end of the wires and they just lot into the connector.
  5. KIAB
    KIAB Super Member
    On your photo, the socket looks like it has different sized pins,maybe the angle photo was taken.
  6. Mike58
    Mike58 Screwfix Select
    THat looks like te more up to date US connectors which have "polarity". The older style with two pins will fit and they are designed to do so, just that a polarised plug with different pin sizes will not fit the older sockets.
  7. Jitender
    We have just left the old LED light on. The spade connectors fit snugly into the socket. i don't think there is any polarity as the LED works both ways.
    Power is on permanently, (i.e without the witch being on/off).
    The belt came yesterday and fitted. It works much better now with no slack. I had to adjust the bobbin winder as wasn't contacting the belt. This was a simple job be repositioning the whole assembly with two screw.
  8. Rona Knowles
    Rona Knowles New Member
    Can you tell me where you purchased the new motor from, and how much was it please
