BSP?
Discussion in 'Plumbers' Talk' started by andyd2604, Feb 21, 2010.
  1. andyd2604
    andyd2604 Member
    what does bsp stand for in relation to tap fittings? just curious...
  2. hibeealex
    hibeealex Member
    Well it used to refer to the thread on fittings ie british standard pipe thread
  3. andyd2604
    andyd2604 Member
    used to? just got a plumber comming next week to fit sink and he asked if I knew the bsp - if not he could check before install
  4. vote CONSERVATIVE
    vote CONSERVATIVE New Member
    sTILL dOES sTAND fOR bRITISH sTANDARD pIPE tHREAD
    LOOCIFER x
    [Edited by: admin]
  5. Tony Soprano
    Tony Soprano New Member
    British Standard Pipe thread is still being used from Australia to Zanzibar :)
  6. tightenit
    tightenit New Member
    Does he need to know which tails are on the taps? Could be standard 1/2" or perhaps you have a monobloc with 10mm / 15mm tails or such like. BSP has nothing to do with the kitchen sink - who's supplying?
  7. imran_
    imran_ New Member
    He'll be turning up in a Ford Cortina by the sound of it! Otherwise he'd stock all fittings for all BSP sizes on his van.
  8. tightenit
    Could be 10/12/15mm tails though some manufacturers thoughtfully include an adaptor to 15mm copper.Just watch the flexi 1/2" to 15mm isovalve jockeys!
  9. andyd2604
    andyd2604 Member
    is bandq sink with a mixer tap, i've no idea about plumbing all i know is there are 2 15mm tails [hot and cold] currently in situ waiting for attachment
