putting a 3mx1.5m utility into a garage. Has entry from conservatory and exit into existing garage. Will have fire door and suitable insulation and roof will be 1.5m below existing garage roof - does it need building regs?
building regulations are fairly standardised, everything built should be designed and built with them in mind - it's planning permission that you should be asking the question about you may well find that you will be allowed to proceed on the basis that the works are a permitted development however advice from your local planning and building regulations department should first be sought
You will need building regs if your house is open permanently to the conservatory. There may be other reasons. Mr. HandyAndy - Really
Hi Sandi, As Sean_ork said... the works may not require Planning Approval, but that depends on a few factors, one of which is whether your property has its PD rights still intact. Only the LPA can answer this for you. As for Building Regulations, yes you will require them. You're converting a non-habitable space into habitable. As well as that, there will be associated drainage works, etc... You could look at dealing with the Building Regulations side under a Building Notice. Even though the same price as a Full Plans application, not as much detail/drawings are required. Regards, Damian Hill DOHdesigns
