Hi I am fitting cold and hot water feeds for a bathroom basin and am using the shutoff valves below. http://www.burlingtonbathrooms.com/Products/ProductDetail?prodId=99200 There is no nut and olive supplied on the feed side of the fitting so assume it is not for compression. If not what is the correct fitting to use ? If it's threaded with a washer i'm not sure how easy this it to fit giving the fitting will be recessed in the stud. Thanks in advance,
Them fancy isolation valves have to be screwed into a suitable female 1/2 inch bsp fitting,in the wall
