Burying armoured cable.
Discussion in 'Landscaping and Outdoors' started by Kelsey, Jun 13, 2021.
  1. Kelsey
    Kelsey New Member
    I’m burying armoured cable in the garden. Are there any special things I need to do for when it surfaces at ground level? Like does it need to be in a vertical container of some sort?
    or can it just pop out of the ground?
    many thanks
    k
  2. AnotherTopJob
    AnotherTopJob Screwfix Select
    Normally it will come out of the ground against a wall, if that's what you mean.
    chillimonster likes this.
  3. Kelsey
    Kelsey New Member
    Kind of. I need to surface it back from the wall and run it along a gravel board. Thanks for the reply
  4. spirits are real 2016
    spirits are real 2016 Screwfix Select
    Who is making the final connections you or a electrician if an electrician you need to seek advice before you bury the cable..
