Hi I have a bush electric oven AE6BFS. When I turn it on as it starts to heat it trips the electrics in the whole house. Anyone have any idea what could be causing this to happen? Thanks in advance Vicky
Short on the element at a guess. If you know what you are doing the easy test is to disconnect the element ( insulating the connections appropriately) turn on and see if it trips. If it doesn’t then order a new element
Thank you Jonathan. That’s a great help, I’m sure my husband can have a go at that and see if this is the issue.
