Cabinet for a slimline dishwasher
Discussion in 'Kitchen Fitters' Talk' started by David DD, Jul 13, 2018.
  1. David DD
    David DD Member
    I shall soon be replacing our kitchen. We have a integrated slimline dishwasher by Howdens that I'd like to keep. It's width is 450mm and height 820mm. This appears to mean it sits in a cabinet and not on the floor. But a standard 450mm cabinet is not wide enough to fit it (due to thickness of walls - 2 x 18mm). So how is the unit housed?
  2. CraigMcK
    CraigMcK Well-Known Member
    Is it not sitting between the two adjacent cabinets with possibly end plates fitted? It's unusual for them to sit inside a cabinet.
    A photo would help
  3. goldenboy
    goldenboy Well-Known Member
    Its not meant to be in a cabinet.
  4. David DD
    David DD Member
    Thank you. Unfortunately I am out of my house at the moment (we holiday let it) and I was relying on old photos I took and data from Howdens website. Thinking about it more I am sure you are correct. I will also call in to a Howdens store to ask.
  5. David DD
    David DD Member
    I think you are right but the height mentioned on the Howdens website suggests it sits on a shelf? Anyway I will call in to a local store to ask. Thanks for replying though.
  6. kitfit1
    kitfit1 Well-Known Member
    No David, the height mentioned suggests it sits on the floor with legs protruding about 50mm to give it a height of 870mm. That is the standard height for all a built under appliance.
  7. David DD
    David DD Member
    I'm sure you are right. Thank you. Makes sense
