Cables inside Celotex
Discussion in 'Electricians' Talk' started by Pikerray, Jan 31, 2009.
  1. Pikerray
    Pikerray Member
    Are there any special regulations or procedures to follow when running cables through studwalls/ceilings/floors, that either have 100mm or 140mm Celotex insulation fitted ?
    The cables are for upstairs power, lights, showers & Jacuzzi, so can I channel the insulation so there is an inch space for the cables to run through.
  2. Clark Kent
    Clark Kent New Member
  3. dja
    dja Member
    I'm in a similar situation. So I can bury the cables underneath the plasterboard in the insulated part (clipped to the wall) without any conduit or other protection (assuming the cables are run in safe zones vertically or horizontally.) Is that correct.
  4. Clark Kent
    dja, as far as I'm aware..
  5. bluevelvet
    bluevelvet New Member
    electricians guide to building regs,section 2.3 method 102
    shows examples of cables run in an insulating material
    wall with contact on one side only
  6. Pikerray
    Pikerray Member
    Cheers :)
