Hello, I am going to be pouring a concrete slab as a shed base to the follow dimensions: 4.8m x 2.7m at 7.5cm thick. Thinkin of going with blue circle ready mix bags but not sure how many I would likely need. Open to alternative suggestions too. Thanks.
You are looking at around 1 cubic metre off all in one ballast plus maybe 15 bags of cement. Cost around £150 ish. A bulk bag typically contains around 0.5 cubic metre. Using ready mix bags - 100 of them at around £5-6 each, so £550 IN both cases you will have mixng time too. Be very sure of the depth, is it onto a firm base or into rough hardcore. Will you need a little more than 1m? you might if itis actually 80 or 85 mm. Also, get some polyester fibres and add a handful to each mix.
I know it's nice to work hard and all, and there's a deep sense of satisfaction in calculating, mixing and laying the measured quantities out perfectly, but I would at least enquire with the local volumetric-mix it on site concrete suppliers how much they would charge for a cube, if it's in the region of £2-250 then I would bite their arm off and save all the faffing about.
Bulk bags of ballast are a possibility. It is a very solid foundation. I have put down type 1 MOT plus a layer of self-binding gravel on top. A little overkill but it isn't going anywhere. Will look into volumetric mix too. The only other company I found was Spotmix.
