I’m a newbie to plumbing and attempting to remove old mixer tap. All guides suggest there a nut underneath the sink which when removed will allow baseplate to be removed. Unfortunately, under mine there is no nut but what looks like a very rusted u shaped piece of metal. Photo hopefully attached. Any tips how this comes off?
What are they chances you can get sink off and flip over. I always took sink off/out and flip over. Fit new tap and drop back on. Get that felt stuff out the way, there is a nut there somewhere. Edit. It's not felt it's rust. Ok. Well get both water pipes off and tap should come off. The nut is missing. I can see now after another look. Might need to tap to shock it (smack) break rusty seal that's holding it. Could be silicone under tap holding it on. That maybe the trouble.
Been a few of these taps posted here lately with a somewhat unconventional fixing method (well, not as common as the ‘usual horseshoe washer, threaded stud and nut job) To me, the threaded stud looks like it has a hex socket head just made for an Allen key (or hex driver) - must be a reason for that ? Give good spray with WD40 type stuff and get Allen key in that stud and try to loosen it off May shield some light on fixing method - good luck
Either an Allen key in the base of the threaded rod or something to do with the white plastic tab sticking out out of the part within the rusted metal (pull or squeeze maybe).
Thanks for the suggestions but so far no further luck. Have managed to remove what look plastic clips using a scissors but the drum shape object above the rusted butterfly plate will not shift. There is no sign of a slot but I think the drum shaped object is the problem. Did consider taking the sink off but the waste water connector will not move with any amount of pressure. I might need to get a professional in ☹️
Many are undone from above the sink with a 5mm long allen key. a photo of the top of the tap around the spout area might show where is it a kitchen sink or a basin ?
Did you try an allen key in the end of the threaded rod to unscrew as Willy suggested? Looks the most likely way to me.
Omg depends on the tap manufacture,this one is all done from above via the pop up rod https://drive.google.com/file/d/0B8I4SiNE6SfAVzdya0VDWTREOUk/view
Can you post a photo of tap itself. As The Teach said, it looks as though it needs a long allen key from the top where the waste pop-up lever is inserted.
Can’t see any sign of a pop up waste rod unless it’s hidden behind the copper tails. I’ve never seen the type of tap that’s mentioned above that fixes from above so will be interested to see how this pans out.
Yes Yes it does doesn't it. The fitting probably dropped through the hole from the top and the white plastic spring flips it out toggle style then you tighten it from above. Edit: Exactly like the drawing Teach posted. Sorry, couldn't open it before.
