Can anyone identify this please?
Discussion in 'Plumbers' Talk' started by Jackie Newsome, Jul 23, 2019.
  1. Jackie Newsome
    Jackie Newsome New Member
    Hiya, just decorating and found this board behind the radiator. Just wondered if anyone knew what it was?
  2. Jackie Newsome
    Sorry image didnt upload
  3. furious_customer
    furious_customer Active Member
    hardboard
    Astramax likes this.
  4. Jackie Newsome
    Thank you. What was it used for? It seems to be in a few pieces . Was a bit worried it might be asbestos
  5. furious_customer
    It's a low-cost and flexible sheet material normally 3mm thick.
    Normally gets used for lining floors before vinyl etc.
    Looks like they might have used it to fill in a chimney cavity maybe?
    Doesn't contain asbestos.
    (Just my opinions, I am not a pro, but I am sure one will be along soon)
  6. furious_customer
    Was also extensively used in the early 80's to cover up gorgeous victorian panel doors to give them a more modern look. (for the time).
  7. Jackie Newsome
    Thanks very much. It's under a window so no chimney cavity. It's also got tinfoil on to reflect heat.
  8. Astramax
    Astramax Well-Known Member
    Can you remove the tape to reveal a little more.
  9. Jackie Newsome
    It wont let me for some reason. Says file too big I'll keep trying
  10. Jackie Newsome
  11. Jackie Newsome
    Finally let me!
  12. Astramax
    Yes..........hardboard , could be 3mm, 6mm or 9mm thick.;) If you remove it, it will have the firms name that installed it written on the back, probably Bodgeit & Scarper Ltd! :D
  13. ESPlumb
    ESPlumb Member
    Is there an air brick on the other side of the wall? It could be an air vent that has been blocked up?
  14. Jackie Newsome
    I have no idea Haha! It's in a bay window if that helps?
  15. Jackie Newsome
    Lol oh dear!
  16. shedman20
    shedman20 New Member
    Foil covered hardboard, if radiator was in a bay window then it was probably put there in an attempt to reflect heat from radiator back into the room rather than going into the wall.
    Heat likes this.
  17. Jackie Newsome
    Great :) thank you!
  18. Heat
    Heat Well-Known Member
    Agree - Has to be foil covered hardboard.
    Very commonly used to reflect heat away from wall into room.
