Can I put a kitchen sink by a partition wall?
Discussion in 'Kitchen Fitters' Talk' started by Caroline, Jun 10, 2013.
  1. Caroline
    Caroline Guest
  2. diymostthings
    diymostthings Well-Known Member
    Hi Caroline. I assume you're thinking of a standard "sit on" worktop sink and drainer on top of a kitchen base cabinet. Why should you worry about a partition wall? The only worry I would have is if you are thinking of an under worktop sink such as a Butler or other heavy sink and you have to fix separately to a stud partition wall in which case there would be problems with the weight bearing capacity of the wall. Can you be more specific?
    diymostthings
  3. Caroline
    Caroline Guest
    Hiya, yes I was worried it would absorb the water, get wet. Is this something I don't need to worry about then?
  4. joinerjohn1
    joinerjohn1 Screwfix Select
    Are you not going to tile the wall behind the sink then ??;)
  5. ramona
    ramona New Member
    As long as you tile around the wall ans use some sealent to keep and worktop/wall joins watertight, you should be OK.
  6. Caroline
    Caroline Guest
    Excellent thank you.
