https://www.screwfix.com/p/jg-speedfit-15apt2p-appliance-tee-15-x-15-x/27471 Or are they just for plastic water pipes? Thanks.
Yes. https://www.johnguest.com/speedfit/product/valves/appliance-tee/ Prefer to use these. https://www.screwfix.com/p/washing-machine-valve-tee-15mm-x-15mm-x/60723 Pegler if you want quailty brand. https://www.screwfix.com/p/pegler-washing-machine-valve-tee-15mm-x-15mm-x/76344
I already got one of that pushfit tee, and tried on. It was leaking on copper pipe, so trying to get the inserts.
Now if I try to use the compression ones, then the cut pipe distance might be too wide, and the compression tees cannot reach both end of the copper pipes. Because that push fit speed fit JG tee is quite wide.
You might find pegler compression tee (below) is a tad smaller in size than the speedfit,so might be ok. A: 56mm
You do not use inserts on copper,only plastic. You cannot have the copper far enough into the fitting to properly make the joint,hence the leak,or the o-ring is damaged.
Yes, this is it. Copper pipe is a bit short. It is because the copper pipe was cut where it had a hole off the B&Q outside tap kit was attached. The pipe was cut just after the hole, but that made the pipe too short.
Yes, ran out to local Screfix branch, and got the Pegler tee. It did the job. Two end of the copper pipe was still short, and there was huge space between one end of the tee and the pipe, but I pulled the pipe hard into the tee, and inserted and tightened with my spanner. It kept coming off, but managed to secure it in the end. Tightened them very hard, and the water is now working without leaks. Thank you. You saved my life. Without that working, we would have had nothing to eat or drink tonight.
Do the compression coupling bit need PTE taped around it? Water works well. Even outside tap is connected to the middle spout using flexi hose, and works well. But there is a tiny drop of leak every 10 sec. from the compression coupling on the tee. I am catching the drops using a wee bucket under the tee.
You could fit one of these,which will give an extra bit of length. https://www.toolstation.com/shop/p6...MIio3intXA3gIVAuJ3Ch2Jpg9tEAQYASABEgLAN_D_BwE
Would it be same / similar one as this one? https://www.screwfix.com/p/repair-fitting-15-x-100mm/85529
You could have tightened it too much,try a smear of water hawk or suitable potable water paste. Yes but the Toolstation one is WRAS approved.
Without taking the compression coupling off? Or should be taken off, and smear on the threads, and tighten it again? I see. It has to come via post then? We dont have the Toolstation branches around here at all, I think.
Checked for the leak from the tee joint in the bucket. There seem hardly any. The bucket is wet, but no sign of actual water in it. It seems not bad for overnight leaks? Still might have to put on some compund on the joint, just to ensure long term good seals?
