Can you do osb, roof membrane then felt?
Discussion in 'Builders' Talk' started by Bobby86, Jul 24, 2021.
  1. Bobby86
    Bobby86 New Member
    I have a kingspan nilvent timber wall and roofing breather membrane. I was thinking of putting the 18mm osb boards on the 2x6 rafters of my single slope roof first then the membrane. I will be using felt nails and felt adhesive for the felt. Can I put felt on top of the kingspan breather membrane? TIA :)
  2. stevie22
    stevie22 Screwfix Select
    What for??
    Clue is in the name: there ain't going to be much breathing through the felt.felt
  3. Bobby86
    Bobby86 New Member
    It's mainly foelr the water proofing as if the felt fails in anyway the membrane is 100% waterproof
