cant find stop tap
Discussion in 'Electricians' Talk' started by sparksgalore, Mar 1, 2006.
  1. sparksgalore
    sparksgalore Member
    got to change a c,u but cant find the stop tap to bond it not even sure where the water enters the flat can anyone offer any suggestions please.
  2. rutspark
    rutspark New Member
    It'll be hidden behind a kitchen cupboard/bathroom panel or some other equally difficult to locate area
  3. X
    X New Member
    There may not be one fitted !!!!
    Was it a conversion ?
  4. state-it
    state-it New Member
    10 houses in the row where I live. All the same look inside & out. All built at the same time.
    Rewired three of the houses.
    I still can't find - nor can the owners - the water stop-cock for the third house I've done. We think the previous owner may well have concreted over in a fit of DIY.
    We are all stumped on this one.
  5. state-it
    state-it New Member
    Bloody editor!! Stop-C-OCK !!!! CO-CK!! COC-K!! Stop-DICK!!!
  6. sparksgalore
    sparksgalore Member
    i think it was converted from a house to two flats its a bit of a mess i was just wondering what to do if you cant find it do you just bond it where ever you can.
  7. X
    X New Member
    valve
  8. state-it
    state-it New Member
    I bonded at best guess where water entry was, and wrote on the Cert that I couldn't definitely locate water entry point.
  9. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    stopcock
    Mr. HandyAndy - really
  10. Ripped Off
    Ripped Off New Member
    Snap I'd do the same its better than nothing
  11. oscar21
    oscar21 New Member
    If its a row of terraces, sometimes every third or fourth house has a stop tap, when I renovated my first house I had to knock on 3 doors away to turn the water off while I fitted my own stop tap, sorry stop cock. ******
  12. sinewave
    sinewave Screwfix Select
    Stick a nail through pipe and run away.
    Come back again the following day and someone will have found or installed a Stop C0CK for you! ;)
  13. X
    X New Member
    Or... if you are realy bothered
    Under the kitchen sink or where ever is easy to get to... freeze the pipe and fit a stopcock
  14. state-it
    state-it New Member
    Yippee!! Thanx Sine!!
    Life seems great again... :)
    [Edited by: forum admin]
  15. squeaky
    squeaky New Member
    LMFAO :-D
  16. squeaky
    squeaky New Member
    That should be
    LMFAO :)
  17. ban-all-sheds
    ban-all-sheds New Member
    As handy said - omit the hyphen (which shouldn't be there anyway), and write "stopcock".
    That way you can coc<u></u>k a snook at the braindead autocensor settings...
  18. Jimbo
    Jimbo Screwfix Select
    OK BAS, how did you get away with that then...? %20cock%20?
  19. ban-all-sheds
    That would be telling, old co<u></u>ck... ;)
  20. Jimbo
    c k ...
    Ah..., I see! Will remember that!
