Yep true. I only mention replacing it because I did mine a couple of weeks ago and was very pleased - the handle is so much easier to turn and it looks nicer
I don’t know why nobody replied to this IIR. I thought your answer explained the symptoms shown on the video. Just a busted connector.
So this seems to have done the trick! There is still a tiny bit of dripping happening from somewhere on the tap, but it is not spraying like it was before and the connector doesn't get blown off either. As for the connector missing tangs, it might look like that in the picture but it's not, there are three tangs, then a hole, then three again, hole etc. That's the way it is supposed to be, so no fault with the hose connector bit itself. As for the tap, I will probably get it replaced in the future as I don't like it much, but for now this seems to work fine! Thank you everyone for the replies, I really appreciate the help!
