hi all dose any 1 put capping over 1.5-2.5mm twin runing down wall have had a look in regs and on site book's and it say's yes if not running witin 150mm from top & 150mm from bottom of wall or partion's but i have spoken to a friend who is niceic and he says you have to is this just good practice or is it a daft nic reg. also have worked with plaster's in past and they also say you have to dose any one out there do this all reply's welcome ant thankyou all.
Look it up on here mate under `capping` it is probably one of the most debated posts on here Basically there are designated routes to run cables if your not in these routes you need to bury the cable 50mm deep or in metal conduit, plastic capping is only used to protect the cable from plastering and doesn't really offer any mechanical protection
Been using capping for a long, long time and dont see any reason to stop. Yes it costs a bit more, but I believe that its a better job when used.
It's also a damned sight better than letting the spreads slice through your sheathing and it's a lot easier to plaster over than cable clips. Plus, I'm always grateful for thoughtfully capped switch drops when I can pull new cable through for a rewire. (I always turn over the ends too, so there are no sharp edges to worry about. Not a requirement, just good practice)
Any wiring outside the zones needs to be in earthed metal conduit. Wiring within the zones including vertical / horizontal runs to accessories (as long as the cables are more than 50mm from the other side of the wall) should be protected with plastic capping. The capping simply prevents the plasterer from damaging the cables.
Yeh I use it. Makes all the first fix look finished and really neat. I then ask for the first fix money and can be farely confident that when I return for the 2nd fix after plastering, the wiring hasnt been knocked about or pulled out of the switch. Cable clips come out too easy.
My pet-hate job capping but I al,wsy use the plastic capping in vert/horiz runs and for the full length and only use metal capping if, on the very rare occassion, have to put cables offline or at angle. I just wish there were better things than capping nails to fix - they are a P.I.T.A RR
My pet-hate job capping but I al,wsy use the plastic capping in vert/horiz runs and for the full length and only use metal capping if, on the very rare occassion, have to put cables offline or at angle. I just wish there were better things than capping nails to fix - they are a P.I.T.A RR but metal capping offers no further protection than plastic. and try using pin plugs, a pain in the ***, but worth it. of course, thats only if you're struggling to get a hold in hard materials. if its soft then, um, araldite?
