Caulk on a painted surface
Discussion in 'Painters' Talk' started by zuk, May 2, 2021.
  1. zuk
    zuk New Member
    Hi there,
    I'm new to home improvements, I apologise for the silly questions!
    I painted my skirting boards yesterday and discovered there is quite a gap between the board and the wall. I'm going to get some caulk to fill in the gap, but since I already painted the board with wood paint (it was primed already), will the caulk stick? Will I be able to paint over it? Do I need a specific caulk to paint over or can it be any?
    The same issue is with my new door frame - there is a gap between the frame and the wall. Can I caulk that part too?
    Thank you.
  2. rogerk101
    rogerk101 Screwfix Select
    Most caulks will stick to most surfaces. Every caulk I've used even sticks to glossy paints, so you shouldn't have a problem at all. Just allow plenty of time for the caulk to dry out between each application, and never use too much of it at the same time. It WILL crack, so be prepared to apply several layers.
  3. Astramax
    Astramax Screwfix Select
    Siroflex Trade Strength Instant Paintable Caulk.
  4. zuk
    zuk New Member
    Thank you for your help! And I'll check out Siroflex caulk.
  5. zuk
    zuk New Member
    How long should I leave between applications? I applied the caulk yesterday, so far no cracks, how long do I need to wait before I start painting?
    Thank you.
  6. Astramax
    If it's the instant paintable Siroflex the clue is in the name, if it isn't the instructions are on the tube.
  7. zuk
    zuk New Member
    Sorry, what I meant was that since it might crack between applications, and it hasn't cracked yet since yesterday, does it mean it won't crack and I can paint?
  8. Astramax
    What product did you buy?....also read the instructions if unsure.
