Caulk
Discussion in 'Painters' Talk' started by Marine boy, Mar 10, 2021.
  1. Marine boy
    Marine boy Member
    Any recommendations from you professionals re painters caulk? I’ve used various brands which are supposed to be over paintable and indeed they are but some never dry and remain sticky, and also under matt paints they show through as a glossy line. I’d like to use a brand that I can trust to produce consistent results.
  2. Wayners
    Wayners Screwfix Select
    Depends on paint.. Ask 10 people get 10 different answers.
    I like nemesis mighty decorators caulk but keep it at room temperature... Summer I can paint over same day but not if its cold and damp like today. Also durable emulsions can play up over and it helps to fill gaps prior to limit the about of caulk used.
  3. CGN
    CGN Screwfix Select
  4. Wayners
    Arkema owns Bostic owns den braven which has a subsidiary called Siroflex who make caulk for screwfix like nemesis and own brand caulks. Was said there are very few manufacturers of caulk. I think some is better as has less water content while others free flows for long quick runs and tends to be cheap as more water than acrylic solids.
    chillimonster likes this.
  5. Astramax
    Astramax Super Member
    Had trouble with the soudal CGN. I caulked around all the edges of a lined wall prior to emulsioning all went well, returned to the address a couple of weeks later on another job and the every wall had a what looked like a greasy dark line where the caulk was, ended up sealing over it with 123 and re emulsioning over.:(
    CGN likes this.
  6. CGN
    CGN Screwfix Select
    Interesting Astra. Seems to work ok for what I do, but I'm not painting all the time.
  7. Marine boy
    Marine boy Member
    Thanks for those replies fellas. Good idea to overpaint with 123 before emulsioning.
  8. Offshore
    Offshore Active Member
    Also had problems with several Soudal products. I find the No-Nonsense brand to be good for sealants and adhesives. Mrs Offshore is the decorator in our house and swears by Polyfilla decorator's caulk.
  9. polybear
    polybear Member
    Are there particular issues when overpainting with durable paints then, and are there any tricks to avoid it - assuming the caulk is "well-cured" (1 week +)?
  10. Wayners
    Durable emulsion seem to be a problem.. It's all hit and miss..
    polybear likes this.
  11. Dr Decorator
    Dr Decorator Active Member
    I’ve been successful with this brand
