Cavity insulation in downstairs toilet
Discussion in 'Builders' Talk' started by Lawrencez, Jan 12, 2021.
  1. Lawrencez
    Lawrencez Member
    I am in the process of reinstating a window that was blocked up in a new downstair toilet.
    The house was built in the 1930's and notice, having removed serveral block that the wall seems to be a standatd 4in cavity.
    Could I install cavity wall batts in the available area, or is it a bad idea to have only part of the wall insulated?
  2. Lawrencez
    Lawrencez Member
  3. kiaora
    kiaora Screwfix Select
    hi
    with the wall ties, it will be a bit ackward won't it ?
    regards
    peter
  4. Lawrencez
    Lawrencez Member
    There are no wall ties from what I can see!
  5. kiaora
    no wall ties ?
    i can't advise sorry, could be a can of worms if you fit insulation
    bridge the cavity, ?
    damp etc...?
  6. Lawrencez
    Lawrencez Member
    Having rechecked I can see wall-ties...
