Ceiling paint peeling?
Discussion in 'Painters' Talk' started by ben100, May 16, 2018.
  1. ben100
    ben100 Member
    My en-suite ceiling paint keeps on peeling away, I have scraped the old paint off & repainted including a mist coat with Dulux paint but it has started peeling again like before. Ventilation is fine in the room any ideas on how to sort this & stop it constantly peeling?
  2. CGN
    CGN Well-Known Member
    You could always clad it. Just sticks up with silicon...piece of **** to fit.
    Corvus93 likes this.
  3. Astramax
    Astramax Well-Known Member
    What finish is the paint, Matt, silk, eggshell?
  4. ben100
    ben100 Member
    Matt
  5. Astramax
    Do you have a shower in the en-suite?
  6. KIAB
    KIAB Well-Known Member
  7. Astramax
    For areas of high humidity and steam an acrylic eggshell finish is the paint of choice also Zinsser PERMA WHITE would also be a good product to use.
  8. ben100
    ben100 Member
    Yes I do
  9. Astramax
    Read post #7.:)
  10. Corvus93
    Corvus93 New Member
    Where could we buy good quality & priced clads? Would it be easy to fit?
  11. CGN
    Its very easy to fit. Just don't assume your room is perfectly square and cut accordingly. Sticks up with silicon. I personally am not a fan as I would rather have a plastered ceiling, but that's just me. The times I have fitted it, the customer has supplied it.
  12. DIYDave.
    DIYDave. Well-Known Member
    Look for a local UPVC supplier as they will be way cheaper than buying from a ‘shed’
    Most trims/cladding channel they will stock in 5mt lengths where as sheds often only have 3mt lengths. Only problem is getting it home if you only have a car (or push bike)
    Some suppliers may even deliver, worth asking
    As ever, compare prices. Don’t think there’s much difference in quality with this stuff ? Maybe, dunno ?
  13. Corvus93
    Corvus93 New Member
    I am thinking of doing the job onto oour upstairs bathroom, but plaster / skimming is option. But I am apprehensive of peeling paint later because it gets steamy and damp, and we leave the window open then.
    Looking at the ceiling, one problem I imagine would be how to cut the cladding exactly fit into the lights (on the middle of the ceiling) and also light switch (which is coming down from the ceiling) they are both round shape.
  14. Corvus93
    Corvus93 New Member
    We have wicks and b&q and screwfix in the town, so will pay a visit & see what theyve got.
    I saw this from Wick site.
    https://www.wickes.co.uk/Products/Building-Materials/Cladding/Interior-PVCu-Cladding/c/1000262
  15. CGN
    Ideally you would remove light and switch first, then you only have to put a hole in for the cable. Neatest way of doing it if you're confident with electrics.
  16. DIYDave.
    As ever, great advice on this site but also, look on you tube for tutorials, loads of help on every subject
    Re your light switch and lights - ur looking at this from the wrong angle
    Remove switch and lights, (isolate power and dbl check circuit is dead 1st)
    Fit cladding, bringing wires from ceiling through cladding - so only say a 20mm hole needed through cladding
    Refit switch and light, securing through cladding into ceiling above (need to check suitability of light fitting and lamp for mounting on cladding, ie temperature)
    You would never cut cladding round fittings as say in future you change light fitting ...... you won’t get exact same size fitting so uv now got a mess
    Depends if your happy messing with electrics as well. Be aware if you have a central light fitting, there may well be more than 1 cable to light, could be 3 = 9 cores so you need some experience
    Might not be, several ways to skin a cat and wire up lights ;)
  17. DIYDave.
    Sorry CGN - both typing at same time !! :)
    CGN likes this.
  18. CGN
    No need to apologise Dave. I tend to be a bit succinct at times with replies...and let you do the hard graft :D
    DIYDave. likes this.
  19. DIY womble
    DIY womble Well-Known Member
    Paint peeling from shiny plaster ? Over trowelled , lightly sand all over , insulated ceiling
  20. ben100
    ben100 Member
    So should I go with the eggshell paint or the Zinsser & is this just a straight application with no need to paint on with any other paint after? Also would the Zinsser Matt finish be fine or should I go with another finish?
