cement or silicone under shower tray
Discussion in 'Plumbers' Talk' started by newkitchenboy, Jun 5, 2008.
  1. newkitchenboy
    newkitchenboy New Member
    Hi
    I am fitting Kudos concept tray (quadrant) details say to use a 1-5 weak cement mix, silicone or tile cement.
    Which do the experts prefer?
    Any tips or hints would be gratfully recieved.
    Ta
    Ian
  2. HOTDOG ø
    HOTDOG ø Active Member
    Do whatever the manufacturer recommends. They all work but there will be no warranty if the tray cracks and you have not followed their instructions.
  3. wetneck
    wetneck New Member
    Hi
    cement.
    Ta
    Ian
    Use weak cement spread over entire base of shower tray,as per MIs. Any probs,your covered;)
  4. tgs
    tgs New Member
    Agree with above absolutely.
    Last Kudos tray I installed, I remembered the tile cement bit being there but not the silicon.
    I used cement based tile adhesive (no lumps in it) and spread with a notched trowel to give a completely even support with leeway for levelling up and adjustment.(courtesy of the notches)
    Most trays have a 25 year warranty or similar so it's worth sticking to manufacturers guidelines.
    I like the bit in the MX leaflet that says that it won't accept the excuse that the instructions in the leaflet couldn't be followed because the tray came without the leaflet. "The tray always comes with the leaflet".
  5. Captain Leaky
    Captain Leaky New Member
    Ah, manufacturers! Bless 'em.
  6. Kelvers
    Kelvers New Member
    Rapid set floor tile adhesive works better, for me, than mortar, but warranty...? Also, it's something I always have in the van.
  7. plumb12
    plumb12 New Member
    like kelvers said,tile adhesive works a treat.nice and stiff when beding the tray.
  8. Captain Leaky
    I like tile adhesive but it is best to stick to the manufacturer's spec to keep the warranty valid.
  9. newkitchenboy
    Hi all thanks for the tips
    I've got some sand and cement I'll do it that way
    Ian
  10. newkitchenboy
    did it with sand/cemnt mix - worked ok
    Thanks for the tips
  11. electric7831
    electric7831 New Member
    hi yeah rapid set tile adhesive is best. if on a wooden floor use a flexible floor adhesive, sand and cement will crack on wooden floor. flexible adhesive sticks to the tray as well and bonds it all together.
  12. bathstyle
    bathstyle Active Member
    I've not used anything other than rapidset flexy for the past few years. I'm not keen on sand/cement.
