MartinPatching
New Member
Went to drain cental heating system to replace a lockshield and damaged 8mm pipe however all radiators drained except the two in the living room they remained fully pressurised even though the drain valve in the hallway was run dry as was the drain valve in the shower room on the opposite side of the hall wall. Replaced the pipe and valve but very confused as to why the only other two rads on the ground floor stayed pressurised and full of water, all trv and lockshields fully open on every rad during drain. Gravity fed system with water turned off anyone please advise??
