Chainsaw recommendation
Discussion in 'Tool Talk' started by Theleman, Dec 18, 2018.
  1. sospan
    sospan Screwfix Select
    Fuel composition has changed dramatically over the the last 50 years, so many of the octanes have changed plus all the additives are completely different
  2. Theleman
    Theleman Active Member
    Yeah it is all made with metal apart from the chain breaker which is plastic and corners are all crumbling.
    It is heavy, but I do weight lifting for keeping fit, so will be ok :)
  3. Dam0n
    Dam0n Screwfix Select
    I wouldn't go any richer than 35-1 personally. 20-1 doesn't seem right for any engine.
  4. Theleman
    I thought it was weird too. Because my Titan and Ryoibi Petrol Hedge trimmer were 40:1, I recall vividly.
    20:1 sounded way off from norm.
    Will take time when I get it, and research and check it for right mixture.
  5. sospan
    number of times I have had people say that - they we start moving sand, cement, blocks or bang in a few hundred nails :D
    Jord86 and Dam0n like this.
  6. WillyEckerslike
    If the saw really is from 1968 then it's very unlikely to have either a chain catcher or a rear hand guard and the AV will not be a patch on modern systems. I wouldn't bother.
    I have a large saw that I've had for 40+ years. It's got bags of power and is a dream to use but I won't anymore for the reasons above. Nor will I ever use a chainsaw on my own - it's much easier for someone else to phone for an ambulance.......
    KIAB likes this.
  7. KIAB
    KIAB Super Member
    Forget it.
  8. KIAB
    KIAB Super Member
    Coldn't agree more,just keep it as a museum exhibit.:D
  9. Theleman
    Lifting 25 kg bag of plaster around garden, plastering huge ceilings, painting, cutting 100 yards of Leylandii hedges 15ft high ... all these are good workout :)
  10. Theleman
    The saw is very similar to this one. It seems pretty good useable saw.
  11. Theleman
    It is not a big saw either.
  12. Theleman
    Seems a good user.
  13. Theleman
    I had to buy a new chain for the Bosch AKE35S for £15 the other day, so for £25 for a vintage chainsaw like this would be a good buy and interesting, and if it starts and works it would be a bonus?
    And I will be also looking into a new Hyundai saw as well.
  14. Dam0n
    I'd be surprised if it works after just putting fuel in it.
    Check the fuel tank for rust and whip the carb off and clean it out. The jets will be gummed up and will need a thorough clean up.
    Check it has compression by removing the spark plug, putting your thumb over the spark plug hole and pulling the starter. You should feel some pressure there.
    If you're just cutting up firewood and it works then why not £25 is a bargain.
    Please please make sure the chain break is working. It can save a world of hurt.
    Enjoy and let us know how you get on.
    PhilSo likes this.
  15. WillyEckerslike
    There isn't a chain brake or rear hand guard. I can't see if there's a chain catcher (although I haven't watched the whole video). Your call.
  16. chippie244
    chippie244 Super Member
    There is a chain brake on some of the videos.
  17. Dam0n
    Seems like there is a chain break on some of the videos but not others.
    I wouldn't bother with it at all if it doesn't have a chain break fitted.
    I've had a few kickbacks before where the chain break stopped the chain before any damage was done. It's not a luxury it's an absolute necessity in my book.
    PhilSo likes this.
  18. WillyEckerslike
    Thank you. That will learn me. I'm at work and was on my coffee break. I'll wait until I'm at home in future.
  19. WillyEckerslike
    If there's no rear hand guard and chain catcher you're still missing some key safety features - chain brake or not.
  20. PhilSo
    PhilSo Screwfix Select
    Felled a cherry tree today.
    40 mins.
    Hit the turf.
    15 year old Tesco 40 cm petrol chainsaw.
    So much fun.
    PhilSo
    Dam0n and Theleman like this.
