Chair and Table Leg Pads
Discussion in 'Kitchen Fitters' Talk' started by Farrow1972, Oct 24, 2021.
  1. Farrow1972
    Farrow1972 New Member
    We are painting your kitchen floor
    What is the best product to fix to the chair and table legs to prevent scratching the paint
    I've heard that the preglued pads do not stay on very long
    Is it possible to fit these with carpet spray or another kind of glue
    Would this be ok to do without removing the glue on the pads
  2. Wayners
    Wayners Screwfix Select
    Screw on teflon chair glides. Fit to table as well
  3. Farrow1972
    Do you have a link for these
    Thanks
  4. Wayners
  5. Farrow1972
    Thanks
    Are the screws long enough
    If not can I use my own screws
    Do I need to drill a pilot hole
    Do they last well and stay in place
    Thanks
  6. Wayners
    Screws were long enough and yes you can buy longer screws or use your own. I went for the screw type because I can swap easy. I think with our busy table and chairs I'll be lucky to get a year out of a set on the chairs but table will last forever.
    Yes you will need a 2- 3mm drill bit. Bought mine from DIY
    Farrow1972 likes this.
  7. Bazza-spark
    Bazza-spark Screwfix Select
  8. Farrow1972
  9. Bazza-spark
    I have them on a coffee table, TV table and stack of 3 nest tables. They only fall off if you pick the table up and haven't stuck them on. Ours haven't fallen off in 12 months.
  10. Farrow1972
    I think it's the chairs that are the problem
  11. Bazza-spark
    Double sided tape to stick them and they will be fine.
    How often do you pick the chairs up?
  12. Farrow1972
    We dont pick them up
    We move them under the table and out from under the table
    Our floor sander recommended spray adhesive
    Just wondering what to do with the existing adhesive
