Change danfoss thermostat to wifi thermostat
Discussion in 'Electricians' Talk' started by Ellis Neill, Dec 2, 2019.
  1. Ellis Neill
    Ellis Neill New Member
    Hi does anyone know if it's possible to swap a danfoss thermostats to a wifi thermostat and how to wire it if possible
    Many thanks
  2. Philip Hyde
    Philip Hyde Active Member
    That looks more like an underfloor heating Stat. temp control won't be as good as a proper room stat plus yours looks battery powered.
  3. peter palmer
    peter palmer Super Member
    Wiring looks a bit odd to that thermostat, almost looks like 3 browns but only 3 connections, you wouldn't need N/O and N/C for the heating. Your new stat definitely needs 3 wires at least, live, neutral and a switch wire.
    I agree it does look like an electric UFH stat as opposed to a boiler one but the last couple of under floor heating jobs I have doe have been supplied with something similar, I've told the firm they are for electric type or at least need a floor probe but you can set them to measure air temp as well apparently.
