Hi all, looking for advise before I make it worst. I replace the horbeck bottom connector valve as this was randomly notshutting off when flushed so was going out via the outsideoverflow pipe. After replacing like for like it has started to leak at the join from the ‘extended’ brass pipe to the plastic tube. As this looks like an extension to the service valve, looks like it has been soldered on, I cannot see if there was a washer there or what thickness it has to be if required. An help please?
Hi, thanks for the quick response. Just trying to get pictures up. I have actually taken off the valve to try and get a few decent pictures if that helps
There should be a fibre washer inside the top nut - usually red. It swells with moisture creating a seal. Edit: You might also have a leak around the bottom of the inlet valve where it meets the cistern. Sometimes difficult to distinguish between the two.
Thanks for that. I was expecting to have a washer there but trying to find out the size as cannot get a decent look, the criteria off. Also noticed that in the picture of the service valve and extension I can see the solder is coming off but definitely was not leaking there.
The solder isn't coming off, it's just that the joint wasn't wiped when it was made. Any DIY store will have the washer you need. Take the fitting with you. The washer should be a tight fit around the copper spigot leaving the brass nut free to move.
Once you’ve replaced the fibre washer, don’t be tempted to over tighten the fitting onto the plastic tail of fill valve - doesn’t take much to knacker the plastic threads and this will also cause the fitting to leak Can buy better quality fill valves that have brass tail, not absolutely necessary, just let the new fibre washer do the sealing without going crazy with the wrench
All good advise, if I have a problem thread/connector I put a smear of LSX on the washer (from plumbers merchants) as said don’t over tighten & get the fibre washer not the nylon type old plumbers used to keep the washer in their mouth for a minute or two to dampen the washer but before adding the LSX
First...dont put tools on the seat cover...it will get scratched. Second...i note you have a 'virgin, toolkit...lol third....make sure the bottom of the cistern where the Torbec valve sits is clean. Fourth...note advice above. Rs
Yes, definitely excellent advise given and just trying to work out the washer size, I know it’s half an inch but it’s the thickness of the washer I am trying to work out. Don’t really want to take the extension piece off as may cause another leak. Lol
I’m only diy me so not plumbing every day but when using metal onto plastic fittings, I put a few wraps of PTFE on plastic thread It’s not to stop fitting leaking, we all know that’s a schoolboy / DIY error In this case the washer will do the sealing, with compression fittings, it’s the olive that seals. Miles of PTFE on the threads is just uneccesary and often left on show, looks messy Just find that with plastic to metal it makes the threads kinda smoother when tightening up Maybe all in my mind but keeps me happy and always have a few rolls of plumbers miracle tape in the toolbox Happy plumbing OP
