Changing switched FCUs to grid switches
Discussion in 'Electricians' Talk' started by k52, Nov 18, 2009.
  1. k52
    k52 New Member
    Hi folks, I have 3 FCUs in a row in the kitchen and am thinking of replacing with grid switches or altering the array.
    1 switched FCU is a spur off the kitchen power ring and controls the cooker hood.
    (Replace with grid 20a DP switch + fuse ?).
    1 switched FCU simply connects mains lighting feed cable(switched from doorway 3gang)to worktop lighting flex tails.
    (I know it might be handy to be able to 'isolate' the worktop lights for bulb-changing, cleaning etc. but would a grid 20a DP switch do instead ? Or just a connector block, even ?).
    Finally, 1 switched FCU+neon supplies the combi-boiler via a fly-lead. The unit is wired radially to 6a MCB (protected side)via 2.5mm TW/E.
    Would a grid 20a DP switch+neon be OK or is a fuse necessary ?
    Many thanks, k52
  2. 1361
    1361 New Member
    Not sure if you are planning to install a single 3-gang plate/box for the 3 switches. This would not be advisable as you would have more then one circuit in there.
  3. gerrin2owd
    gerrin2owd New Member
    Err, so what?
  4. pcelectrics
    pcelectrics New Member
    yes
    no, yes
  5. k52
    k52 New Member
    necessary ?[/i] no, yes
    Hi, could you explain your reasoning, please ?
    Thanks, k52
  6. k52
    k52 New Member
    Hi, thanks for your reply. I thought that one of the advantages of the grid system was that you could have more than one circuit in there...
    I could be mistaken, of course !
    k52
  7. k52
    k52 New Member
    Sorry pc, I have re-read your reply -you mean grid 20A DP + fuse (neon optional) ?
    Thanks k52
  8. pcelectrics
    You asked two questions in one
    Would a grid 20a DP switch+neon be OK no
    and
    is a fuse necessary ? yes (3 amp max)
  9. k52
    k52 New Member
