Changing thermostat
Discussion in 'Electricians' Talk' started by Steven Sandell, Oct 11, 2018.
  1. Steven Sandell
    Steven Sandell New Member
    I recently purchased a new thermostat for combi boiler, looking at the old one there's a brown wire going to l and and blue cable going to l1, the new thermostat has N, L, dry and contact.
    Where do the wires go please...
  2. Bazza
    Bazza Well-Known Member
    Dry, contact? What's that mean?
    Pictures of the wiring of the old and the terminals on the new one please.
    If that's difficult, the make and model number of both devices.
  3. Steven Sandell
    Here's the new thermostat
  4. Allsorts
    Allsorts Well-Known Member
    Are you sure that Stat also has a built-in sensor? Because it does look as tho' it's designed for UFH with a remote sensor.
    Anyhoo, wiring that one ain't the problem - the problem is what wires do you have, and where did they go on the old stat. If you really only have two wires, then I believe you are stuffed and will need a battery-operated Stat.
    Can you post a pic of the old one?
  5. Steven Sandell
    This is the old one
  6. Allsorts
    Cheers.
    What's the front like? And does it take batteries?
  7. Steven Sandell
    Front and yes does take batteries
  8. Bazza
    The new thermostat needs a neutral, and you haven't got one. And as above post #4, it looks like the wrong stat anyways. (Make/model numbner will help.....)
    Whatever the outcome of that, If you are going for a digital stat, you are either going to have to rewire it, or get a stat that takes batteries.
  9. Bazza
    That's the old one isn't it?
    Its the new one we need the info on.
  10. Steven Sandell
    Box for new one
  11. Steven Sandell
    Face of new stat
  12. Bazza
    This is hard work
    What is the
    MAKE and MODEL of the new thermostat??
  13. Allsorts
    Steven, that new stat won't work without an additional neutral wire since it doesn't run on batteries.
    Yes, it looks nice, But I would suggest an alternative, one that is battery-powered. If you insist on keeping it, then you'll (a) need a further wire installed and (b) need to confirm that is has a BUILT-IN heat sensor to detect the actual room temp.
    It may have, but it isn't certain.
  14. Steven Sandell
  15. Steven Sandell
    It does have a neutral wire but has been cut short and not in use, apologies for my vague replies
  16. Steven Sandell
    Info
  17. Steven Sandell
    Info
  18. Steven Sandell
    Wiring
  19. Bazza
    I’m sorry, Steven. The cable to the existing stat has only live, boiler call and earth.
    There is no neutral in that cable.
    Ps. The wiring diagrams show, in all cases, a temperature probe being attached. I don’t know if that is what you expect?
  20. Steven Sandell
    Oh dear unsure what to do next..
