Channel 5
Discussion in 'Builders' Talk' started by fooman, Apr 20, 2010.
  1. fooman
    fooman New Member
    Cowboy builders you lot should be ashamed of yourselves :^O
  2. TheFunkyMonkey
    TheFunkyMonkey New Member
    I especially liked the idea of using 2.5 T&E clips for the ufh then Tiling right over it.
  3. joinerjohn
    joinerjohn New Member
    I especially liked the view of her bottom as she was looking at the timbers in the roof space. Looked like her jeans were sprayed on from the inside. ;)
  4. wilson
    wilson New Member
    Does everyone call out building control when they fit an outside light
  5. ThreadJacker
    ThreadJacker Active Member
    her jeans were sprayed on from the inside. ;) ;-)
    Damn right!
    It seems they said you need to be Gassafe to represurise a combi, or did I hear it wrong?
  6. inkpad
    inkpad New Member
    'Part P clearly stats that a socket must be about 50-60cm away from a sink' - do it? does 7671 even say that? that vaguely?
    'I'd have put it up here a bit'
