Cherry pickers.
An you usually jump all over the place in a cheery picker when entering a building or going over a speed bump.
It is quite possible to have a slide rail in a scissor lift to allow a 1m harness to slide from one end to the other without restricting you unecessarily, but they are not needed because you don't have the catapult action you get with a cherry picker.
Scissor lifts are stable at low level where a cherry picker will hurl you like a conker.
Nope pointless having a rail at one side of it, makes the full platform useless. We use both types and no need for a restraint only a harness in a scissor lift
Never used a van mounted one so don't know the rules but on one you can drive I am correct
yes I have said you are right but not right for the reasons you are stating, not all cherry pickers are mobile. Ours are classed as static as we cannot drive them whilst being used, we have outriggers on the van and can only operate the cherry picker once the outriggers are deployed.
Back
Top
