Chisel?
Discussion in 'Carpenters' Talk' started by Ruffnek, Dec 28, 2005.
  1. Ruffnek
    Ruffnek New Member
    Whats your preferrred brand of and chisel?
  2. big all
    big all Screwfix Select
  3. Ruffnek
    Ruffnek New Member
    cheers mate!
  4. limestone cowboy
    limestone cowboy New Member
    I've had these for years:
    and have been very pleased with them.
    [Edited by: admin4]
  5. Duke
    Duke New Member
    Big all, how does the quality of the blade compare to the slightly cheaper Marples chisels, like the £25 for 4 type sets?
    The reason I ask is I've never had any of my handles split, but the quality of the blade has never been great. I'm not sure if these chisels at £45 are actually better, or if it's just the handles.
    I was budgeting about £100 per 4 if anyone has any other suggestions?
  6. big all
    to be honest i dont know duke as i have never used the cheaper version but i would assume lower quality steel
    but as i say i dont know
    you could try there wed site and ask them!!!!!!
    http://www.irwin.co.uk/WOODWORKING/m373.htm
    big all
  7. mj
    mj Guest
    The red & yellow marples/irwin chisels are very good, i've had mine since 1981. The 1" & 1 1/4" have worn out & been replaced. Never split a handle yet & they get some abuse with a claw hammer. The blades hold a good edge if you look after them & don't overheat them when grinding.
  8. mj
    mj Guest
    [Edited by: forum admin]
  9. problem
    problem New Member
    Red and Yellow Marples over here as well, excellent quality and you get the replacment if you ** the handle.
    Also if you've not already, get yourself a decent sharpening station.
    Passy
  10. Duke
    Duke New Member
    Right, I'll give them a try them. £50-£60 seems going rate for the 6 piece set, so I'll budget the rest on a decent sharpening kit. My diamond wet-stone has seen better days.
    Thanks.
  11. bodget&scarpers
    bodget&scarpers New Member
    im still using some marples blue chip firmers, remember them,but still hold a razor edge!
