Circular saw jammed
Discussion in 'Carpenters' Talk' started by tiler7777, Mar 24, 2020.
  1. tiler7777
    tiler7777 Member
    So I have bought a brand new circular saw.
    Fitted the blade with the Allen key.
    Turned the thing on and tested the blade.
    The safety guard thing has come down a bit and the blade may have hit it. It's now jammed. Never even touched a piece of wood. Don't know if it is me or a faulty saw.
    I've tried to use the Allen key to take the blade off, it's stuck solid must be a safety switch.
    The guard that came up when I put blade up is stuck solid at 8 o'clock to the left. It came right up to 12 when I put the blade on don't know what happen.
    Is there anything I can do?
  2. Severntrent
    Severntrent Active Member
  3. Astramax
    Astramax Well-Known Member
    I expect you have but if not............isolate it from the power supply! :)
  4. tiler7777
    tiler7777 Member
    It is isolated from the supply. I plugged it backin again and tried again and I could smell a burning from the motor.
    Noone any idea if it's my fault or a manufacturer fault?
  5. Jord86
    Jord86 Well-Known Member
    What brand of saw? Did it come with the blade or did you buy one separate? Most saws have a button to lock in and hold down over the body and then use the Allen key to undo the screw, it’s probably a reverse thread so turn it clockwise.
  6. tiler7777
    tiler7777 Member
    It is brand new and came with the blade.
    Your right there was Allen key with it which I used to attach the blade no problem. Now it's jammed and the Allen key won't turn even if I hit it with a hammet
  7. CraigMcK
    CraigMcK Well-Known Member
    It sounds like the blade lock is still engaged. Photo or at least model number would help. However don’t try turning it on you will just break it if it’s not already.
  8. CraigMcK
    Also I assume you have fitted the correct blade for the saw. That is outer diameter and inner bore?
    barbaricduck likes this.
  9. Astramax
    Sounds like the allen key is the cause of the trouble.
  10. Jord86
    What’s the make of the saw?
  11. Severntrent
    Sounds like the OP is the cause of the trouble :)
  12. barbaricduck
    barbaricduck Active Member
    Unless there is something seriously wrong I am suspecting user error.
  13. CGN
    CGN Well-Known Member
    Woolworths.
    Jord86 likes this.
  14. Astramax
    Old stock then!
    CGN likes this.
  15. sparky steve
    sparky steve Active Member
    Think this may have become a bit of a saw topic for the op now:D
    Astramax and CGN like this.
  16. Jord86
    Thought as much, I suppose it’s one up from Silverline at least. Probably why the guy hasn’t clarified what make, too embarrassed.
    CGN likes this.
  17. Astramax
    It's from the 'Bob The Builder' franchise either that or 'Tonka'.
  18. Jord86
    Astramax likes this.
  19. Astramax
  20. dobbie
    dobbie Well-Known Member
    Borrowed from kiab's tool and paint warehouse.
