Cleaning Stained Pebble Dash
Discussion in 'Getting Started FAQ' started by DrEcosse, May 15, 2019.
  1. DrEcosse
    DrEcosse New Member
    We recently had to get some repair work done to the rear wall of our house. As part of that process a trellis was removed, which uncovered a stained section under a central heating overflow.
    What's the best way to clean this, also it's right next to the reinforcement patch, which had only just been completed?[​IMG]
    Update: I can't seem to let you guys/ gals see the photo I took, as the image icon wants a URL and I chose my Dropbox account to store it. So, apologies for all the icons - which I can't get access to for deletion!
    [​IMG]
    [​IMG]
  2. Astramax
    Astramax Well-Known Member
    Use Sodium Hypochlorite 2 parts water to 1 part Sodium Hypochlorite, see YouTube re patio cleaning, keep moist whilst activating for an hour and wash off with a hose pipe. Repeat if required. Wear mask, gloves and protective overall. ;)
  3. DrEcosse
    DrEcosse New Member
    Thanks Astramax!
  4. Astramax
    My own drive before and after cleaning with Sodium Hyperchlorite.
    CGN and dobbie like this.
  5. Astramax
    It was laid 29 years ago, just wondering should I seal it?
  6. DrEcosse
    DrEcosse New Member
    It looks good to me!
    Just FYI: I got a new patio built a couple of years ago and used Resiblock. My brother-in-law recommended it and it's great but not cheap!
    I tried to do it in a hurry at the end of Autumn, the problem is you need good sunshine to do it properly. Mine didn't seal as well as his but when done properly, the results are great!
    Astramax likes this.
