Clear Silicone sealant for glass splash backs
MikeyT
New Member
Can I use Soudal sealant for base of kitchen splash backs ?
I'm removing my glass splash back panels from my kitchen worktop. They are screwed in place on the vertical walls and I need to replace the silicone clear sealant at the bottom where the glass meets the laminate kitchen worktops.
I have seen a sealant on Screwfix: "Soudal Fix All Crystal Super Clear Sealant and Adhesive", I'm hoping this would be the best product as it has a blue pigment making it a super clear look.
I don't need to use it as an adhesive though as the panels are screwed to the wall (small splash back panels).
If you think this is not the best product could you suggest any of your other similar products with a super clear look.
I'm a little unsure as I don't need to permanently fix the sealant to the worktop and may need to be able to remove it and replace it in a few years time should it become discoloured in any way.
Best wishes. Mike
Yes. What I call a polymer mastic.
You can paint it or leave it and the clear is useful stuff..
Don't have so much flex as some silicone though but you don't need it to flex
Back
Top
