Combi Boiler Filler Plug?
Discussion in 'Engineers' Talk' started by glob@l, Sep 9, 2018.
  1. glob@l
    glob@l Member
    The image shows the plug used for topping up water in a combi Boiler. Is that what this item is called or is there another name for it? I cant seem to find it on the host website under that name anyway.
  2. Heat
    Heat Well-Known Member
    It is called a Filling Key, or water pressure filling key.
    But each manufacturer might have different names for it
  3. The Teach
    The Teach Well-Known Member
    Doubt they will stock it,its more specific to your boiler. Which boiler is it ?
    is the shaft snapped ?
  4. glob@l
    glob@l Member
    The shaft is fine!
    I have always inserted a screwdriver into the hole in the end to adjust the flow of water, so when it wouldn't grip enough to turn it, I naturally thought I needed a new one. However as it has a square box shape on the end I will just use a spanner instead, no real hardship..
    Thanks all!
  5. glob@l
    glob@l Member
    Everything I've touched today seems to be breaking.
    What is the item in the image? It's the bung which is inserted before the water flow is adjusted.
    The boiler is British Gas branded but I just can't for the life of me remember the make G... something?
  6. Heat
    Gloworm?
  7. The Teach
  8. The Teach
  9. glob@l
    glob@l Member
    I don't thimk it;s Gloworm.
    Thanks for ebay links etc.
  10. glob@l
    glob@l Member
    The part number on the flikr link above corresponds with the number on my T key, so it must be a Worcester then?
    Are these T keys of a standard size?
  11. CGN
    CGN Well-Known Member
    Looks like Worcester Bosch to me.
  12. glob@l
    glob@l Member
    It would seem British Gas do fit Worcester Bosch and the part number (8716102872) I have on my filling loop charging key points in the same direction. Anyone know where to get one at a reasonable price?
  13. CGN
    EBay possibly?
