Combi heat only
Discussion in 'Plumbers' Talk' started by Jeremy85, Oct 10, 2018.
  1. Jeremy85
    Jeremy85 New Member
    Hi all. im putting a system in my workshop offices with 5 rads and an oil boiler. ive planned it for open vent heat only condensing oil boiler as i already have it however ive just been offered a much newer combi that id like. ive never needed to know this so never asked before but can i use the combi for heat only? i dont see why not as no water demand will ever be asked for, but id like to confirm?
    thanks all
  2. kiaora
    kiaora Well-Known Member
    hi
    most likely be a pressurized system, just need a filling loop.
    the boiler output, will be for hot water, so heating load will be less.
    basically no problems
    regards
    peter
  3. The Teach
    The Teach Well-Known Member
    Getting the boiler output correctly sized to the radiator requirement is fairly important,using a combination oil boiler will need some installer adjustment and a means to stop pre heating of the internal heatstore.
    All doable :)
  4. Jeremy85
    Jeremy85 New Member
    many thanks for the reply guys. another plumber has said simply stick a tap on the wall connected for the hot water and open t once a week to keep things good. think i might do that,
  5. The Teach
    *** :D
