EEvenin.. I use a combination square on a daily basis... Problem is, they don't tend to last that long. The bolt always ends up snapping or wearing thin so i end up buying a new square. Does anyone know of anywhere i can buy just the bolt/nut?
heeelllooo heeennnoo there are so many makes and they are all different so maybe contact the manufacturer!! i re-made one for an old stanley thought it would be a 20 minuit job ha ha took 3 hrs and i was using files angle grinder bench grinder ect big all
Really,you get what you pay for. I have a Moore & Wright combination set that I've had since I was an engineering apprentice, 40 years ago. I can't remember how much it cost, but probably £20+ (a lot of money then)but it's still accurate and nothing is broken,although it's been well used.
They're a lot money now:- http://moore-and-wright.co.uk/main/combset.htm So, did the £20, 40 years ago feel like as much as the £197 + VAT they're asking these days? Cheers, Pete.
What are you doing with it to snap the bolt ?! The most common problem generally is knackering the spring. You should never overtighten the nut on a combi square. Just do up enough, so there is still some spring in the spring....if that makes sense !!
i am assuming we are talking one off these !!! http://www.screwfix.com/prods/33486/Hand-Tools/Measuring/Combination-Squares/Stanley-Combination-Square-300mm;jsessionid=0ATWW4Y0SKKJICSTHZOCFFQ big all
Are you buying a cheap model? Another problem could be rusty finger. In that your body excretes higher levels of acids and yucky stuff, and this causes corrosion of metals.
What are you doing with it my combination square is older than me gets used on a daily basis and is still working fine.Must be one of the cheap flimsy ones, get a decent stanley and that should be fine.
Buy a proper one made from cast steel they will last a lifetime,I suspect you have one of the cheap di cast monkey metal ones.
"get a decent stanley and that should be fine." Decent Stanley?..That seems to be a contradiction of terms nowadays. All that I have seen of Stanley lately is overpriced tat, specially if it has the "FatMax"label. Stanley aren't the firm they used to be.
I have a Rabone Chesterman one that is at least 15 years old. Battered but works fine, after some TLC with sandpaper and WD40...Probably my most used piece of kit.
"FatMax"label. Nothing wrong with the Fatmax 5m and 8m tapes, in fact I don't see any alternative to them ..
